kompresor za 4x4 VIAIR 300p in vlečni trak
maister
Prispevkov: 4
Pridružen: Po Sep 01, 2014 8:09 pm
Kraj: Celje
OdgovorNapisal/-a maister » Sr Mar 21, 2018 3:53 pm
VIAIR 300p
[img]https://mmc.bolha.com/3/image/222457/223315/Mocan-kompresor-za-polnjenje-ofroad-gum_5ab26a9fd877b.jpg[img]
80€
mob. 070333445
4 leti star
zelo malo uporabljen
[url]www.viaircorp.com/portables/300p[url]
FILL RATES
31″ X 10.5″ FILL RATE
0 to 30 PSI 3 min. 25 sec. (± 10 sec.)
15 to 30 PSI 2 min. 00 sec. (± 05 sec.)
33″ X 12.5″ FILL RATE
0 to 30 PSI 5 min. 00 sec. (± 10 sec.)
15 to 30 PSI 2 min. 45 sec.(± 05 sec.)
FEATURES
– 5-in-1 Inflator/Deflator Air Hose with Inline 100 PSI Gauge
– Aluminum Sand Tray with Vibration Isolators
– Deluxe Dual Compartment Carry Bag
– 40-amp Inline Fuse Holder
– Dual Battery Clamps
– 3 pc. Inflation Tips Kit
SPECIFICATIONS
– 12-Volt
– Permanent Magnetic Motor
– Duty Cycle: 33% @ 100 PSI
– Max. Working Pressure: 150 PSI
– Max. Amp Draw: 30 Amps
– Ingress Protection Rating: IP54
– Dimensions: 9″L x 4.9″W x 7.5″H
– Net Weight: 8.70 lbs.
– Power Cord Length: 8 ft.
– Air Hose Length: 25 ft.
se na voljo
ARB vlečni trak 20mx80mm, 11t - 50€
[img]https://mmc.bolha.com/3/image/222457/223313/ARB-vlecni-trak-20mx80mm--8t_5ab263f4377bd.jpg[img]
ARB trak za drevo 5mx75mm, 12t - 30€
[img]https://mmc.bolha.com/3/image/222457/223082/ARB-trak-za-drevo-5mx75mm---12t_5aabbd2d5416d.jpg[img]
Prispevkov: 705
Re: kompresor za 4x4 VIAIR 300p in vlečni trak
OdgovorNapisal/-a rx » Sr Mar 21, 2018 5:44 pm
Da bodo slike delovale je treba v zadnjem [img] dodati še poševnico /.
Koda: Izberi vse
 [/img]
maister
Prispevkov: 4
Kraj: Celje
OdgovorNapisal/-a maister » Sr Mar 21, 2018 6:35 pm
80€
mob. 070333445
4 leti star
http://www.viaircorp.com/portables/300p
FILL RATES
FEATURES
SPECIFICATIONS
– 12-Volt
se na voljo
maister
Prispevkov: 4
Kraj: Celje
OdgovorNapisal/-a maister » Sr Mar 21, 2018 11:56 pm
ponudbo, prodajamo nujno
maister
Prispevkov: 4
Kraj: Celje
OdgovorNapisal/-a maister » Če Mar 22, 2018 4:09 pm
Prodano!
:skace_od_srece:
se star 5 let extreem sotor imam
Ferrino synchro 3
https://youtu.be/lO7hBRtbJUc
in samonapihljiv jogi
uporabljen je bil samo za offroad
cena je simbolicna
Vrni se na “Offroad tržnica”
Po forumu brska: 0 registriranih uporabnikov in 147 gostov
