T I S O V E C 2012 Slovaška 12-15. 4. 2012
- Prispevkov: 727
Pravila so
in še
OFFROAD KLUB TISOVEC napisal/-a:Tisovec Preparations for 2011 are in full swing and I would like to acquaint you with the changes that will bring this year. Of last year was very wet. The weather is nice pohralo with us so we had to move the date of the event. Allow us to at least get into the mountains and prepare
lines. Still, it was so wet that the track on some sections, after dozens of cars pass became impassible. Only with great effort we managed to move the cars further down the track. We complained to the nedisciplinovanosť number of crews, which could not or would not cooperate.
Some crew virtually ignored marshals, especially younger ones.
Therefore we are forced to accede to some changes.
- Changing the number of registered mainly in the 200 crew
- Every vehicle must be equipped with functional winch, power winch must meet weight car
- Tire model MT with a minimum depth of greater than 10 mm model
- Gurtňa Tying the tree in navijakovaní (if not the organizer of her crew can throw a line without returning the entry fee. If it finds the action, the crew will be able to start next year.)
- Gurtňa or rope tow, kit
- Every car passed the technical acceptance prior to registration and shall be clearly marked
- At the entrances to the organizers will track, preventing excursion without registration and technical acceptance
- May drive only person with valid driving license
- Alcohol and arrogant behavior will not be tolerated
We prepared and pleasant changes. During the trophy you can also zasúťažiť, a Specialty will be measured and the best three times will be evaluated nice prices. Evaluation of the competition will start on Sunday before the trial in the valleys. On Sunday we prepared in competition navijakovaní, where the main prize will Winch Superwinch EP9.
Registration will run the first week of February.
We look forward to your participation.
Offroad club for Tisovec Miro Koncos
in še
OFFROAD KLUB TISOVEC napisal/-a:After meeting representatives of off-road clubs in Slovakia, created the general conditions of the compulsory equipment of vehicles, depending on the category of action. The organizer has the right course, rules for its share tinker to suit the nature of the event. The attached table shows the different categories. The main category is added previous category, so you have Extreme in the category of equipment is calculated previous categories, preferred category may modify some rules of the previous categories. In the case that as you lose, you should be using the enclosed table. To share OFFROAD TISOVEC ALLMETAL 2011, will apply the technical rules under the SPECIAL category. A technical screening is not controlled Batteries (headlamp), CB Radio / PMR and pulley to forever. NOTE: Vehicles that do not have seat belts as standard (UAZ), this element must have to share!
ORIGINAL
- tire model A/T
- gurtňa
- 2x šakel
- first-aid kit
- towing eye (hook)
- fire extinguisher (1 kg)
- spare wheel / opr.sada
- Torch (Headlamp)
- a firm grip battery
- serial jack
- 3bod. seat belts
ŠTANDARD
- tire model M / T
- Hi lift (firmly attached)
- 2x towing ok
- spare wheel with identical tires
- CB Radio / PMR
+ original
ŠPECIAL
- navijak (min.ťažná sila 1,5 násobok celkovej hmotnosti auta)
- 2x gurtňa (krátka + dlhá)
- pneumatiky min. hĺbky dezénu 10 mm
- kladka k navijaku
+ štandrad
EXTREME
- rollcage (min arch behind the front seats)
- 4point bod. Safety Pay
- tire tread min.hĺbky 15 mm
- 2 fire extinguisher (1 kg)
- Battery disconnection
- Winch (min.strength 2 times the weight of the car)
+špecial
Alien, tako da smo videli v Tisovec? Najdete avto http://img856.imageshack.us/img856/7569 ... r6zd1x.jpg
- Gašperček 413
- Prispevkov: 234
- Pridružen: Ne Mar 19, 2006 1:32 am
- Kraj: bled
Še moje slikce:
https://picasaweb.google.com/srogac/Tis ... directlink
- Prispevkov: 727
Po forumu brska: 0 registriranih uporabnikov in 94 gostov
