hallo from Greece
I have a LADA niva 17i and I search wich way to get 7 cm higher in this moment i have a panel+ 3cm and wears 205R16 you know how?
thanks
niva greece
FOr front or rear axe?
SOme pictures you will find here:
http://www.nivaoffroadteam.com/?page=mods/lift_gregor
Its the part of this page.
thank you slayer
this is my project
http://clubs.pathfinder.gr/getphoto.php?album=114493&pic_id=2
http://clubs.pathfinder.gr/getphoto.php?album=114493&pic_id=1
http://clubs.pathfinder.gr/getphoto.php?album=114493&pic_id=3
but i want another 3 cm
this is my project
On the front dont lift too much... If u lift 3 cm on the front spring and 3 cm on the ball that is enought. That is about 6 cm total lift. 3 cm on the ball is maybe too much. You lose optic performance of your niva. And it be inefficient to drive on the asphalt road.
For rear axe i recommend you lift for about 5 cm. If you go more then 5 cm you will break the propulsion from the central diferencial.
If you drive only off-road with your niva you can go for about 1-2 cm higher on each axe. But on your own responsability. I dont recommend yout. Buy higher wears.
And sorry for my bad english.
I believe my English is very bad
I don't believe it is the 6 cm height, because from palls you don't take any height
that you have made in the base of spring it is good and safety?
have you any problem from the additional height ?
make preparations for trophy and I have put crown & pinion 4:3 from 3:9 that it had and I want the height in order to I put bigger tyre, the 205/80/16 it finds in the dome.
Po forumu brska: 0 registriranih uporabnikov in 107 gostov
