Daihatshu rocky 2.0 benzin
jugy13
Prispevkov: 9
Pridružen: To Jan 24, 2017 10:35 pm
OdgovorNapisal/-a jugy13 » Ne Feb 19, 2017 1:39 pm
pozdravljeni.
mene zanima če bi vedel kdo kašen motor bi šel notri v rockya. Jaz imam notri 2.0 benzin in bi rad dal notri malo bol navit motor.Pa me zanima ali je že kdo predelavau in ve več o tem.
Prispevkov: 4405
Re: Daihatshu rocky 2.0 benzin
OdgovorNapisal/-a Nebivedu » Ne Feb 19, 2017 1:52 pm
BMW-jevi motorji so bili v bertone modelih.
Assembled in Italy for European sales, this version called the Bertone Freeclimber used mechanical components by Daihatsu, although it was powered by a BMW 2,443 cc turbodiesel or one of two BMW petrol engines (1,991 cc and 2,693 cc), with a Bertone modified body. The Freeclimber is a well-equipped, high-end deluxe (luxury car) off-roader produced from 1989 to 1992. In France, where only the diesel was available, the importer Chardonnet offered an even more luxurious version. Named after a perfume by Nicolas de Barry it was called "Blue Lagoon", and was available with either Alcantara or leather interior.[1]
jugy13
Prispevkov: 9
OdgovorNapisal/-a jugy13 » Ne Feb 19, 2017 2:11 pm
aha kaj pa še kašen motor turbo diesel od kakega avta bi šel notri.
Prispevkov: 4405
OdgovorNapisal/-a Nebivedu » Ne Feb 19, 2017 2:13 pm
Ali si si prebral post?
BMW 2443 turbodizel
jugy13
Prispevkov: 9
OdgovorNapisal/-a jugy13 » Ne Feb 19, 2017 2:21 pm
ja sem ok hvala za nasvet.
game-on
Prispevkov: 286
Pridružen: Ne Okt 31, 2010 10:17 pm
Kraj: Ptuj
OdgovorNapisal/-a game-on » Ne Feb 19, 2017 4:09 pm
Glede na to da trdiš, da imaš 2.0l bencinski motor predvidevam, da govorimo o prvi generaciji Rockyev (listnato vzmetenje spredaj), ker v drugi generaciji ni bilo opcije 2.0l motorja, temveč 2.2l. So pa takrat, v prvi generaciji, bile na voljo 3 opcije motorjev - 2.0l bencinski Toyotin 3Y motor (tega imaš torej ti), 2.8l dizel ter 2.8l turbodizel. Prvi ima 88 konjev, enako slednji, drugi pa 77 konjev. Prvi 155Nm navora pri 3.400rpm, drugi 170Nm pri 2200rpm ter tretji 245Nm pri 1900rpm. Če ti uspe najti slednjega ti ga priporočam. V VB gredo za drobiž in so praktično neuničljivi motorji. Najboljša rešitev bi verjetno bila, da kupiš enega v VB in ti ga pošljejo (vprašanje koliko bi prišla poštnina, vendar pa smešno visoka ne bi smela biti).
Nazadnje spremenil game-on, dne Ne Feb 19, 2017 4:21 pm, skupaj popravljeno 2 krat.
game-on
Prispevkov: 286
Kraj: Ptuj
OdgovorNapisal/-a game-on » Ne Feb 19, 2017 4:18 pm
Na facebooku je angleška skupina "Daihatsu Fourtrak / Rocky / Sportrak owners", če boš iskal kakšne dele ali pa torej motor. Sicer pa jaz osebno motorja ne bi menjeval, so 2.0l bencinarji dandanes že dokaj redki, napram 2.8l D/TD.
Še eno vprašanje. Ima štirikotne ali okrogle sprednje luči?
jugy13
Prispevkov: 9
OdgovorNapisal/-a jugy13 » Ne Feb 19, 2017 9:58 pm
lp luči so kvadrataste oblike enega imam z platneno streho mislim da letnik mora biti 1986.
drugega pa imam z fiksno streho letnik pa 1989 oba imata iste menjalnike. enega bi pa rad porihtal za offroud.
jugy13
Prispevkov: 9
OdgovorNapisal/-a jugy13 » Ne Feb 19, 2017 10:22 pm
kaj pa za tale motor ki si mi omenil VB za njega prvič slišim bi mi lahko mi malo pojasnil. o njem ali se ga da dobiti pri nas?
game-on
Prispevkov: 286
Kraj: Ptuj
OdgovorNapisal/-a game-on » Ne Feb 19, 2017 10:22 pm
Kvadrataste luči so bile del posodobitve, ki je vključevala tudi neke malenkosti pri motorjih - kakšne oz. če so sploh bile pri 2.0l bencinarjih pa ne vem povedati. Varianta menjalnika pa je bila samo ena, če se ne motim, torej ročni 5 stopenjski.
Je pa Rocky odlična osnova!
Toliko za idejo. Ta ima 2" suspension lift in 2" body lift, diferenciale LC 75 serije in pa 33" gume.
game-on
Prispevkov: 286
Kraj: Ptuj
OdgovorNapisal/-a game-on » Ne Feb 19, 2017 10:33 pm
VB - Velika Britanija. Je bilo ogromno Daihatsujev prodanih v Britaniji in je zato tam tudi ogromno delov. Recimo tam pride Feroza (tam imenovana Sportrak) v normalnem stanju 500€, medtem ko pri nas 1000 in navzgor. Enako z Rockyi (pri njih Fourtrak), za 1000€ dobiš pri njih že dobrega.
Najlažje boš zato poceni in dober motor dobil pri njih. Če ti pa pade sekira v med, pa se bi verjetno dalo najti kaj pri sosedih italijanih.
In če boš delal za offroad:
http://www.protrack.gr/proionta/daihatsu/adm-menu/rocky/103-daihatsu-rocky-air-locker.html - link do edinih lockerjev na trgu
http://www.4wdaction.com.au/forum/viewtopic.php?f=108&t=135469 - review linkanih lockerjev
http://xpajun.com/index.php?cPath=102_67&osCsid=c65a1485b548f4d2fb5a6619f504ea34 - tukaj imaš body lifte
http://www.bloodredoffroad.com/ - tukaj boš pa našel amortizerje in še kaj (izdelujejo tudi HD stvari)
jeep corporation
Prispevkov: 1310
Kraj: Skopo
OdgovorNapisal/-a jeep corporation » Po Feb 20, 2017 6:58 am
imam motor 2.0 turbo bencinar ki je bil v rockiju, pokliči če te zanima o4o697872
www.4x4exe.net
jugy13
Prispevkov: 9
OdgovorNapisal/-a jugy13 » Po Feb 20, 2017 5:00 pm
ja jas zdej benziski motor nebi dal notri nevem nekateri mi pravijo da preveč pije in da tudi za povodi in po blatu hitro pride do okvare niso lih tako kot dizli nevem kaj naredit . in pa spet večina pravi da dam notri turbo disel ampak fora je o tem da nevem kateri bi šel notri. in pa iščem da se da motor tudi lepo navit do 150km za dizla govorim več nerabim. takoda eni mi pravijo da tam turbo benzinca eni pa turbo dizel.
game-on
Prispevkov: 286
Kraj: Ptuj
OdgovorNapisal/-a game-on » Po Feb 20, 2017 5:08 pm
Konec koncev bi te še najceneje prišlo, če prodaš tega in kupiš turbodizla. Pa verjetno tudi precej lažje od iskanja motorja bi bilo.
Pa to misliš delat le za offroad/neregistriranega? Ker drugače boš še imel probleme s homologacijo. Seveda, če boš dal motor, ki je že serijsko previdven za Rockya (2.8 D ali TD), potem bo šlo. Vse drugo pa bo precej, precej težko, če ne že skoraj nemogoče homologirati.
Poglej še malo na mobile.de. Se včasih prodaja kakšen brez papirjev, ki bi lahko bil odličen darovalec ;) Ampak spet vprašanje, če bo kje blizu in ne predaleč.
jugy13
Prispevkov: 9
OdgovorNapisal/-a jugy13 » Po Feb 20, 2017 6:27 pm
Ja zdej prodat mi ga je žau ker je že use skoraj narejeno samo motor bi dau drugi noter ker ta je prešvoh. en turbo dizel al turbo benzinca.
5x4
Prispevkov: 992
Kraj: Slovenija
OdgovorNapisal/-a 5x4 » To Feb 21, 2017 8:37 am
jugy13 napisal/-a:Ja zdej prodat mi ga je žau ker je že use skoraj narejeno samo motor bi dau drugi noter ker ta je prešvoh. en turbo dizel al turbo benzinca.
model, a se ti delaš mal norca al si pola pismen?
