A je mogoče kdo poskusu to podvozje? http://4xfourart.com/Product/178/SAMURA ... rings.aspx
Kar se pa kita iz ebayja tiče ni neki sm poskusu.... In blažilci ki trdijo da so daljši od standarda niso nič daljši
Poslano z mojega STF-L09 z uporabo Tapatalk
Podvozje samuraj sj80
primorec 90
- Prispevkov: 316
- Kraj: Vogrsko
Re: Podvozje samuraj sj80
Glede na sliko to ni pravo podvozje ..
- wazapsucker2
- Prispevkov: 27
- Pridružen: Sr Dec 06, 2017 1:50 pm
Ja na sprednjem difu je potrebno šalco vzmeti privarit....primorec 90 napisal/-a:Glede na sliko to ni pravo podvozje ..
- wazapsucker2
- Prispevkov: 27
Samurai
1) 4” Front coil length 44 cms
2) 4” Rear coil length 42 cms
3) 4” front shock open length 52.5 cms
4) 4” front shock closed length 33 cms
5) 4” rear shock open length 49 cms
6) 4” rear shock closed length 31.5 cms
SAMURAI 4 " (10CM) SUSP. KIT (COIL MODEL 1996+)
FRONT COIL SPRING
REAR COIL SPRING
SHOCK ABSORBER FRONT
SHOCK ABSORBER REAR
REAR LATERAL ROD BRACKET
FRONT LATERAL ROD BRACKET
FRONT LATERAL ROD
REAR LATERAL ROD
COIL CARRIER - STEEL
COIL CARRIER SEAT
FRONT TRAILING ARM, LEFT
FRONT TRAILING ARM, RIGHT
REAR TRAILING ARM, LEFT
REAR TRAILING ARM, RIGHT
BRAKE HOSE - REAR
BRAKE HOSE - FRONT LEFT
BRAKE HOSE - FRONT RIGHT
SPECIAL ROD END
4WD TRANSFER CASE FRONT SHAFT FLANGE
REAR SHAFT FLANGE
REAR COIL STOPPER
BUSHINGS – FULL SET
To se dobi pri tem kitu
FRONT COIL SPRING
REAR COIL SPRING
SHOCK ABSORBER REAR
FRONT LATERAL ROD
REAR LATERAL ROD
COIL CARRIER SEAT
BRAKE HOSE - REAR
SPECIAL ROD END
REAR SHAFT FLANGE
REAR COIL STOPPER
BUSHINGS – FULL SET
- wazapsucker2
- Prispevkov: 27
Evo še slike... In prosim za mnenja... https://goo.gl/photos/f8zkZaHJc4XjmgkdA
Po forumu brska: Bing [Bot] in 13 gostov
