P: 16W LED delovna luč 12/24V, 6500K
Objavljeno: Pe Dec 06, 2013 6:04 am
Napisal/-a daemon
Led luč je bila samo vzeta iz škatle je nova in nerabljena.
cena: 40 Eur
Kontakt na ZS ali pa na tel. št.: 041 929 315, Andrej
Specifikacije LED luči:
Input Voltage: 9-32V DC
Power Consumption: 4W*4pcs
Current Draw: 1.34A @ 12V; 0.67A @ 24V
Color Temperature: 6500K
Beam Pattern: Spot Beam
Housing Material: Die-cast Aluminum Housing
Lens Material: PMMA(Polycarbonate)
Mounting Bracket: Stainless Steel
Electronics: Integrated-Epoxy Encapsulated
Operating Temperature: -40?C to +60?C
IP Rating: IP67
Protections: Reverse Polarity
Dimensions: 75 x 80 x 82mm
Weight: 0.5kg
slike:
