LandRover Discovery EXTREME build
Global Trek Off-Road
Prispevkov: 10
Pridružen: So Dec 31, 2011 6:17 pm
Kraj: SLO - Ankaran
OdgovorNapisal/-a Global Trek Off-Road » Po Jan 02, 2012 2:36 pm
So...i was driving that Disco for 6-7 before i start to understand that the time as come, All the "standard" modification is not enough.
We finish few costumers Vehicles, and start to build our own.
Based on 1998 LR Discovery TDI300 EDC.
The idea was to put inside full American GM power-train.
Small Block Chevy 350 4 Bolt.
GM 700R4 GearBox.
DANA 300 Transfer case.
DANA 60 Front and Rear.
90 Degree approach angles.
Front & rear winches.
Rear radiator.
37-38 inch Tires.
FIA Roll Cage.
And set of 16" Coil-Overs that will handle all this extra weight.
Nazadnje spremenil Global Trek Off-Road, dne Po Jan 02, 2012 3:56 pm, skupaj popravljeno 1 krat.
Global Trek Off-Road - 4x4 Shop - Slovenia, Ankaran. - http://www.global-trek.com
Prispevkov: 10
Kraj: SLO - Ankaran
OdgovorNapisal/-a Global Trek Off-Road » Po Jan 02, 2012 2:41 pm
Taking 35cm off, from the rear end.
Prispevkov: 10
Kraj: SLO - Ankaran
OdgovorNapisal/-a Global Trek Off-Road » Po Jan 02, 2012 2:57 pm
Roll Cage - 48.5mm tube / 3.7mm wall.
Prispevkov: 10
Kraj: SLO - Ankaran
OdgovorNapisal/-a Global Trek Off-Road » Po Jan 02, 2012 5:10 pm
DANA 60, modified for DANA 80 Axle-Shafts 35 spline, And Disc Brakes.
Prispevkov: 10
Kraj: SLO - Ankaran
OdgovorNapisal/-a Global Trek Off-Road » Po Jan 02, 2012 7:32 pm
charlie
Prispevkov: 35
Pridružen: So Mar 03, 2007 10:04 pm
OdgovorNapisal/-a charlie » Po Jan 02, 2012 9:02 pm
Impresivna reč... smem vprašat, koliko konjev / navora ima mašina? Kakšna je poraba, teža avta?
V načrtih kakšna dirka? :)
Prispevkov: 10
Kraj: SLO - Ankaran
OdgovorNapisal/-a Global Trek Off-Road » Po Jan 02, 2012 10:13 pm
Yes, of course.
Engine :
GM Small Block 350 V8.
Aluminium Pistons 9.5 - 10.5 compression ratio.
Edelbrock hydraulic Camshaft - 1500 - 6500 RPM range.
Edelbrock Pro-Flo 1 EFI Systems - 425 HP.
Summit Racing Aluminium Heads.
The car weight around 2500 KG.
The fuel consumption can move between 25L to 50L for 100 KM.
This Disco was build for close Rock-Crawling race's ( hard to find here).
Already planing another one, Maybe with the same Drive-line.
This time only tube chassis.
lahko noč
S
TRCO1
Prispevkov: 784
OdgovorNapisal/-a TRCO1 » To Jan 03, 2012 8:43 am
ta pa je hud ..... :aplavz: :aplavz: :aplavz: :veselo_za_volanom:
ben1
Prispevkov: 69
Pridružen: Ne Jan 27, 2008 7:44 pm
Kraj: Gorenjska
OdgovorNapisal/-a ben1 » To Jan 03, 2012 9:36 am
To je bil pa kar projekt. :shock:
Pohvalno.
charlie
Prispevkov: 35
OdgovorNapisal/-a charlie » To Jan 03, 2012 11:32 am
Je v načrtu kakšna dirka? :)
Prispevkov: 10
Kraj: SLO - Ankaran
OdgovorNapisal/-a Global Trek Off-Road » To Jan 03, 2012 12:31 pm
Hvala :nazdravljamo:
I'm using Google Translate (for now :buta_z_glavo_ob_zid: ) to understand the questions. So i hope that i got it right.
The last race was Xsports, I think that it's a very very nice race.
I'm not familiar with another race in this scale in Slovenia, but I'll will be happy to know, hear, invited to some...If there are.
Quadracer
Prispevkov: 173
Kraj: Zg. Savinjska
OdgovorNapisal/-a Quadracer » Sr Jan 04, 2012 10:46 am
:aplavz: bravo, zelo pohvalno!
Prispevkov: 1426
OdgovorNapisal/-a Dr.Patrol » Sr Jan 04, 2012 11:26 am
Very nice!
I need to come see once close up this piece of machine and visit your store :wink:
Prispevkov: 10
Kraj: SLO - Ankaran
OdgovorNapisal/-a Global Trek Off-Road » Sr Jan 04, 2012 1:15 pm
you are more than welcome to visit.
Prispevkov: 10
Kraj: SLO - Ankaran
OdgovorNapisal/-a Global Trek Off-Road » Če Jan 12, 2012 4:09 pm
Found an old photo on the GSM.
http://www.global-trek.com/Online-catalogue
Po forumu brska: Google [Bot] in 26 gostov
