katero olje v kardane (pogone ) frontera
Objavljeno: Po Feb 23, 2009 11:57 am
Napisal/-a maggio
menjal bi olje na pogonih pri fronteri pa me zanima kaj se naliva zadaj v kardan - spredaj in v menjalnik.
Objavljeno: Po Feb 23, 2009 5:46 pm
Napisal/-a sportage
V kardane prav nič-z mastjo se pa maže križe-kardanske zglobe,v kolikor niso tovarniško namazani in zaprti.
Objavljeno: Po Feb 23, 2009 8:03 pm
Napisal/-a maggio
dobro mislim v diferencial al kako se že reče
Objavljeno: Po Mar 09, 2009 7:49 pm
Napisal/-a maggio
ok. zgleda da o tem nobeden nič ne ve
zdaj pa še eno vprašanje ali naj v svoji fronteri samo dolijem mankajoče olje ali ga naj komplet menjam v menjalniku in pogonih.
a je to enako olje in katero se najpogosteje uporablja.
Objavljeno: Po Mar 09, 2009 10:32 pm
Napisal/-a jeep corporation
Povej natančneje katero frontero imaš(A?, B?, Motor?), pa bom lahko pogledal
Objavljeno: To Mar 10, 2009 9:31 am
Napisal/-a maggio
končno en
frontera A 2.3tdi
Objavljeno: To Mar 10, 2009 9:50 pm
Napisal/-a kloshar
Engine 23 DTR Capacity 5,7 liter
Use: Normal
Service intervals:
Change 7500 km / 12 months
SynPower MXL 0W-30
SynPower 0W-40
SynPower 5W-30
Transferbox Capacity 1,45 liter
Use: Normal
Service intervals:
Check 15000 km / 12 months
Change 45000 km / 36 months
SynPower 5W-30
DuraBlend FE 5W-30
HD 40
Differential, rear, limited slip Capacity 1,9 liter
Use: Normal
Service intervals:
HP GL-5 80W-90
Differential, front (4x4) Capacity 1,7 liter
Use: Normal
Service intervals:
HP GL-5 80W-90
Differential, rear Capacity 2,3 liter
Use: Normal
Service intervals:
HP GL-5 80W-90
Transmission, manual Capacity 2,95 liter
Use: Normal
Service intervals:
SynPower 5W-30
DuraBlend FE 5W-30
HD 40
Hydraulic clutch system
Use: Normal
Service intervals:
Brake & Clutch Fluid DOT 3/4
Hydraulic brake system Capacity 0,4 liter
Use: Normal
Service intervals:
Change 24 months
Power steering
Use: Normal
Service intervals:
Check 30000 km / 24 months
MaxLife ATF
ATF Type D
Cooling system Capacity 10,9 liter
Use: Normal
Service intervals:
Coolant AF Extreme
vir: valvoline lubricant advisor
Objavljeno: Sr Mar 11, 2009 11:03 am
Napisal/-a maggio
@kloshar
ornk si se potrudil
hvala najlepša ti dala
Objavljeno: Če Mar 12, 2009 6:52 pm
Napisal/-a maggio
kupil bi 5 l tega olja HP GL-5 80W-90 kje ga pa dobim v lj
Objavljeno: Če Mar 12, 2009 8:20 pm
Napisal/-a def110
maggio napisal/-a:kupil bi 5 l tega olja HP GL-5 80W-90 kje ga pa dobim v lj
Anet, Motomat, Potokar, AC, vsi Petroli, I.S.T., ...
