BRDM Rusija
Korando
Prispevkov: 351
Pridružen: Če Feb 24, 2005 11:09 am
Kraj: Trebnje
BRDM Rusija
OdgovorNapisal/-a Korando » Če Okt 12, 2006 11:37 am
This vehicle was made from Russian “BRDM”, if to translate literally it is “Combat Reconnaissance/Patrol Vehicle”, armored scout car made in Russia.
There were plenty of such in Arabic countries like Iraq or Iran or Syria also.
But this is not a regular military vehicle. It was bought by a Moscow entrepreneur and was pimped up heavily.
First of all it is an amphibian vehicle – it can both move by roads and swim by rivers or lakes.
It is powered with V8 5.5 diesel engine to carry its multi ton body across the Russian roads. It has four general wheels but there are four more, hidden under its bottom, if somebody comes to a road like this he can push a button and use four additional wheels to make his road.
It has of course a multi speaker sound system, GPS navigation, TV, DVD and a periscope to see clearly what’s going on when you are swimming across the nearest lake. Also there is a sonar mounted with which the car owner can monitor the water under his so to say car. Night vision system is there too.
The car is fully registred in road inspection so the owner can drive across the normal roads, and then go to the lake for some fishing or water skiing, after that at night he can come to Moscow casino without visiting home.
VIR http://englishrussia.com/?p=381
:shock: ..... kupim 8)
Sven
Prispevkov: 1092
Kraj: wajdušna
OdgovorNapisal/-a Sven » Če Okt 12, 2006 6:35 pm
Kupi valuka ali krpana, sej je podoben :lol:
TUDI NA FB>>>KLIK
Korando
Prispevkov: 351
Kraj: Trebnje
OdgovorNapisal/-a Korando » Pe Okt 13, 2006 8:08 am
A, to pa ni glih res.
Ta gre tudi po vodi, pa dodatna 4 kolesa ima (8x8 po potrebi), pa radio ima, pa bullbar, pa sonar za ribe lovit, ... , pa s karbonom oblito sklopko ... :twisted:
no use for a name
Prispevkov: 38
Pridružen: Če Dec 22, 2005 7:28 pm
Kraj: Ljubljana-Tobruk
OdgovorNapisal/-a no use for a name » Po Nov 13, 2006 2:24 pm
Bronevaja razvedivatelnaja dosornaja mašina - nekaj takega je originalno ime.
Drugače jih ima pa tudi SV
Only in a Rover..
