katero olje v kardane (pogone ) frontera
menjal bi olje na pogonih pri fronteri pa me zanima kaj se naliva zadaj v kardan - spredaj in v menjalnik.
- jeep corporation
- Prispevkov: 1310
- Kraj: Skopo
Engine 23 DTR Capacity 5,7 liter
Use: Normal
Service intervals:
Change 7500 km / 12 months
SynPower MXL 0W-30
SynPower 0W-40
SynPower 5W-30
Transferbox Capacity 1,45 liter
Use: Normal
Service intervals:
Check 15000 km / 12 months
Change 45000 km / 36 months
SynPower 5W-30
DuraBlend FE 5W-30
HD 40
Differential, rear, limited slip Capacity 1,9 liter
Use: Normal
Service intervals:
HP GL-5 80W-90
Differential, front (4x4) Capacity 1,7 liter
Use: Normal
Service intervals:
HP GL-5 80W-90
Differential, rear Capacity 2,3 liter
Use: Normal
Service intervals:
HP GL-5 80W-90
Transmission, manual Capacity 2,95 liter
Use: Normal
Service intervals:
SynPower 5W-30
DuraBlend FE 5W-30
HD 40
Hydraulic clutch system
Use: Normal
Service intervals:
Brake & Clutch Fluid DOT 3/4
Hydraulic brake system Capacity 0,4 liter
Use: Normal
Service intervals:
Change 24 months
Power steering
Use: Normal
Service intervals:
Check 30000 km / 24 months
MaxLife ATF
ATF Type D
Cooling system Capacity 10,9 liter
Use: Normal
Service intervals:
Coolant AF Extreme
vir: valvoline lubricant advisor
Use: Normal
Service intervals:
SynPower MXL 0W-30
SynPower 0W-40
SynPower 5W-30
Use: Normal
Service intervals:
SynPower 5W-30
DuraBlend FE 5W-30
HD 40
Use: Normal
Service intervals:
HP GL-5 80W-90
Use: Normal
Service intervals:
HP GL-5 80W-90
Use: Normal
Service intervals:
HP GL-5 80W-90
Use: Normal
Service intervals:
SynPower 5W-30
DuraBlend FE 5W-30
HD 40
Use: Normal
Service intervals:
Use: Normal
Service intervals:
Change 24 months
Power steering
Use: Normal
Service intervals:
MaxLife ATF
ATF Type D
Use: Normal
Service intervals:
Coolant AF Extreme
Po forumu brska: Bing [Bot] in 45 gostov
