Popravilo in obnova Patrola
Pri Patrolu bi rad zamenjal razdelilno kapo vžiga in rotorček.
Povprašal pri Avtodelih Novak. Turbo shop, Euroton, Herkules, pa nikjer v katalogu ni za tak avto.
Je pa Nissan Patrol 3.0 Bencinar
Letnik prve registracije 1996 drugače verjetno letnik 1994, ker je TR
Tip motorja RB30
Delovna prostornina 3926ccm
Št. šasije VSKWSG260U0537790
Kje lahko to kupim oziroma naročim. Rd bi pa novo ne rabljeno.
Hvala in lep pozdrav
Tip motorja RB30
evo, nekaj zgooglal:
Four models of 3.0 L RB30 were produced:
RB30S - carburetted single-cam
RB30E - fuel-injected single-cam (114 kW @ 5200 rpm, 247 N·m (25.2 kgf·m) @ 3600 rpm)
RB30E R31 Skyline - fuel-injected single-cam (117 kW @ 5200 rpm, 252 N·m (25.2 kgf·m) @ 3600 rpm)
RB30ET VL Commodore - fuel-injected single-cam turbo (150 kW @ 5600 rpm, 296 N·m @ 3200 rpm)
This motor was produced for use in the Skylines, Patrols and Cefiros, and rights bought by Holden because the Holden 202 (3.3 L) powering the Holden Commodore could no longer satisfy tightening emissions requirements, and with all new cars required to run on unleaded petrol by 1986, a quick replacement was needed. Nissan Motor Co. sold the RB30E to Holden for the VL Commodore. The RB30E in the VL suffered from cylinder head cracking due to the radiator being fitted lower in the engine bay,0 air locks in the cylinder head. This was not as severe in R31 Skyline as the radiator is mounted higher. The engine proved to be very reliable apart from this issue. The RB30S was found in some Middle Eastern R31 Skylines and in some Nissan Patrols. The RB30E was found in R31 Skylines and VL Commodores in Australia as well as in South African R31 Skylines (with 126 kW @ 5000 rpm and 260 Nm @ 3500 rpm)
The turbocharged RB30ET (producing 150 kW) was found only in the VL Commodore (available in all models) and consisted of a lower compression RB30E bottom end, more powerful oil pump, T3 Garrett turbocharger, 250 cc injectors and a different intake manifold. The motor itself is still popular today (albeit in highly modified form) on the Australian Drag Racing circuit.
Nissan Special Vehicles Division Australia produced two limited models of R31 Skylines, the GTS1 and GTS2. These contained slightly more powerful RB30E engines, containing longer opening duration cams and better flowing exhausts.
Vzel kapo dol in znotraj našel tole.
Številka na kapi T61275 na rotorju pa ni nič številk. Na kapi je znak mitsubishi na rotorju pa mitshubishi in nissan. Po moje se dobi to v kompletu, ker rotor nima nič številk.
Med ploščico na rotorju in kontakti na kapi je lufta cca 6-7 mm. Je to normalno, al je že tolk obrabljeno?
ker očitno voziš unikat, dvomim, da boš kje najdel kapo in rotor za tvoj model.......
internet nix, tec-doc nix, nissan f.a.s.t. nix......
ampak.....naletel sem na patrol gr (y60) z 4.2 bencinarjem, pravtako šestak, in mo v tec-doc po sliki zgleda zelo podoben, če ne isti.......
priporočena cena naj bi bila okoli 12€
