Jeep Erorr code
mamaMicka
Prispevkov: 294
Kraj: severni del juga
Jeep Erorr code
OdgovorNapisal/-a mamaMicka » Pe Dec 24, 2010 9:23 am
Prosil bi za pomoč. Na OBD mi javi te dve napaki, pa mi nekako ne potegne kaj bi to lahko bilo narobe. Sveti check engine. Razlike v delovanju in porabi NI. Check engine ne sveti vedno, sveti 2 tedna, nato spet 2 tedna ne sveti...
gre za GC 4.7V8
Najlepša hvala!
P0171 (M)
System too Lean (Bank 1)
A lean air/fuel mixture has been indicated by an abnormally rich correction factor.
P0174 (M)
System too Lean (Bank 2)
Mitsurugi2
Prispevkov: 660
OdgovorNapisal/-a Mitsurugi2 » Pe Dec 24, 2010 10:00 am
Senzor.
VM - Turbotronic®
Mitsurugi2
Prispevkov: 660
OdgovorNapisal/-a Mitsurugi2 » Pe Dec 24, 2010 10:03 am
171 The oxygen sensor is saying that the system air/fuel mix is far too lean (too much fuel is being added as a correction).
174 The oxygen sensor is saying that the system air/fuel mix is far too lean (too much fuel is being added as a correction).
Kokr sm jst bral o 4.7 na ameriških forumih naj bi se o2 senzor hitro zapacal.
VM - Turbotronic®
mamaMicka
Prispevkov: 294
OdgovorNapisal/-a mamaMicka » Pe Dec 24, 2010 6:07 pm
kje pa najdem ta senzor? Nekaj takega sem predvideval, da je lahko...
Mitsurugi2
Prispevkov: 660
OdgovorNapisal/-a Mitsurugi2 » Pe Dec 24, 2010 6:12 pm
Verjetno ima dva upstream in dva downstream.
Nekoč sem nekje zasledil sliko ki prikazuje kje točno so senzorji. Bom poskusil poiskat.
VM - Turbotronic®
zacki
Prispevkov: 298
Kraj: ljubno
OdgovorNapisal/-a zacki » Pe Dec 24, 2010 6:38 pm
tale slikca ti bo mogoče pomagala 8) 8)
lepe praznike :vinska_bratca:
Mitsurugi2
Prispevkov: 660
OdgovorNapisal/-a Mitsurugi2 » Pe Dec 24, 2010 7:17 pm
Točno to sliko sem imel v mislih. Zdej pa na delo :D
VM - Turbotronic®
Tono
Prispevkov: 74
Kraj: Ptuj
OdgovorNapisal/-a Tono » Ne Dec 26, 2010 3:32 pm
Ali imaš falšluft na sesalni strani, počeni izpušni kolektor oz. avspuh pred lambda sondo (sondama?) pred katom, ali pa sta sondi postarani/zanič. Mogoč je tudi prenizek tlak goriva. Najverjetnejša je varianta številka 1, glede na kilometre tudi varianta št. 3.
Lp,
Tono
marjan
Prispevkov: 1133
OdgovorNapisal/-a marjan » Sr Dec 29, 2010 9:48 am
zacki...zanima me če bi mi lahko pripopal sliko od grand cherokija 4.0 1995 letnik avtomatik,ker bi tudi rabil takole slikco...hvala
zacki
Prispevkov: 298
Kraj: ljubno
OdgovorNapisal/-a zacki » Sr Dec 29, 2010 10:16 am
Marjan si imel v mislih kaj takega??
to je za 4.0 motor
to dvoje sem na hitro našel, če rabiš še kaj več povej :mrgreen:
marjan
Prispevkov: 1133
OdgovorNapisal/-a marjan » Sr Dec 29, 2010 10:28 am
superca si:)
hvala
p.s....ali imaš te načrte na računalniku,oz datoteko,ali si uporabil google?
zacki
Prispevkov: 298
Kraj: ljubno
OdgovorNapisal/-a zacki » Sr Dec 29, 2010 11:28 am
imam manual za jeep letnik 1997,... 8)
kar pa tam noter ne najdem pa google vprašam :wink:
Po forumu brska: Google [Bot] in 8 gostov
